Comparing Two Pairs of Mono's
lovelexicon
« on: 6 Sep 2021, 07:17 pm »
The Odyssey Stratos Mono Extreme and the Van Alstine DVA225 are priced the same---$3,400 a pair.
Which pair would you choose, and why?
Thank you for your opinions.
I.Greyhound Fan
Re: Comparing Two Pairs of Mono's
« Reply #1 on: 6 Sep 2021, 08:45 pm »
I reviewed the 225 for Frank but I have not heard the Stratos or any other Odyssey gear but would like to.
I liked the general tone of the 225's.  No glare or harshness.  They are very dynamic and musical with very good detail and resolution.
Bass is powerful and treble was smooth.  But as usual, the rest of your system comes into play for the final sound.  I also like their small footprint.  I guess the only issue is that they are balanced only and you would need a converter for SE use.  My system is fully balanced.
I would also consider the AVA DVA 850 mono's which have SE and XLR.  They sound sublime.
« Reply #2 on: 7 Sep 2021, 12:17 am »
Is this your review with some nice photos ?
https://www.audiocircle.com/index.php?topic=172943.0
I.Greyhound Fan
« Reply #3 on: 7 Sep 2021, 01:15 am »
Yes.  The photo's were from one of Franks engineers though.
lazydays
« Reply #4 on: 8 Sep 2021, 05:18 am »
first of all I like tubes! Yet years back I went the solid state route with the grand idea of using Maggies. They wouldn't fit inside the room very well, so the amps just sat there in the boxes. Fast forward a couple years, and the tube amp is developing some issues. I called Mr. Bunge about a "tune up" before installing them, as I bought them used. He did exactly as I asked him to do, and met me at work to deliver them. A year or so later they got fried in an electrical storm. He wanted to repair them as a warranty thing, but I said no as it wasn't his fault. We worked out a deal for another upgrade and some cables. Mine are what was called the "glass ceiling" version (actually the first). They sound nothing like the Extremes, but something on a much higher level.  You will have a hard time over driving them! I can't!! Yet they are also very smooth, and somewhat tube like.
Break in time is a killer with these amps. Plan of 400+ hours, but they'll sound nice after about fifty hours. They just seem to get better. They don't seem to be bothered by impedence loads. Be it 16 Ohm or 2 Ohm. To be exact they are stable in a one Ohm load forever. They don't get hot. Forget about that power rating, as it means nothing. I think he rates them at 180 watts into eight Ohms. Trust me it's closer to three hundred. They'll do 900 watts in a one Ohm load all day long if you can stand music that loud!  I have a record that has a bad reputation for cooking amps and speakers (six or seven so far plus seven or eight speakers). Those amps simply cruise thru the LP like it was a CD.
What I don't like about them! I hate the rear mounted power switch. At 75lb. each; you best have a pair of good amp stands!
What I like about them:
* build quality is outstanding, and Bunge stands behind his work.
* sound quality is somewhat tube like, but mine have always had a tube preamp in front of them. These amps are at their best with a tube preamp in my book.
* sound is pretty detailed, but not too technical. In otherwords very analog
* If your listening to anything from Miles davis to Ray Wylie Hubbard; you can't do much better. Jazz trios really shine with proper spacing and the bass is right.
* most solid state amps I've listened to have a slight tendency to be bright, and if not bright then grainy. These amps are almost tube like. Very smooth, but honestly they
   are not Conrad Johnson ST140's. I rate them better than Accuphase, Classe, and similar to Sonic Frontiers but with five times the power. Would I buy the glass ceiling
   amps again? Probably not! I'd buy the Khartago SE mono blocs. If for no other reason than the weight and size alone. Plus I just don't see a need for that kind of power
   in my old age
gary
