Audio/Video Gear and Systems
(Moderators:
JohnR
Blackmore
what is "front line equipment" ?
0 Members and 1 Guest are viewing this topic. Read 1465 times.
Matt123
26 Aug 2021, 10:10 am »
Sorry if this post is not in the correct location, but I'm not sure where it ought to go.
What is front line equipment? I think it means everything prior to the power amp, but I'm not sure about this.
Thanks in advance!
Craig B
Re: what is "front line equipment" ?
26 Aug 2021, 11:19 am »
If you mean front end equipment (which is how I've always heard it), my experience has been it means signal source components, upstream from the preamp.
Big Red Machine
Reply #2 on:
26 Aug 2021, 11:22 am »
Do you mean front end gear? Typically sources of muzak like CD or LP and the preamp. So you are correct if that is what it is, that everything after the preamp is the back end. Not sure where the line is drawn with those using integrateds.
Dieterle Tool
I don't know what it is, but I wunt it.
Reply #3 on:
26 Aug 2021, 06:32 pm »
For the wood pushers...
Seriously, I would guess it is similar to "front end" equipment. Meaning your source.
sebrof
Reply #4 on:
26 Aug 2021, 08:28 pm »
Where did you hear front line equipment? Maybe a little context would help.
(Moderators:
JohnR
Blackmore
