Sapphire Audition Impressions
0 Members and 1 Guest are viewing this topic. Read 5575 times.
dlynch34
Re: Sapphire Audition Impressions
« Reply #40 on: 20 Aug 2021, 12:53 am »
The X3 wouldn't suite my listening space. The X3 is better suited to a listening position at least 10 feet from the speakers because the AMT mid/tweeter has a narrow angle of dispersion. The X3 mid/tweeter is also open in the back while the mid/tweeter on the M3 Sapphires is closed, so, again, the X3 will want to be out into the room farther than the M3 needs to be.
The AMT mid/tweeter is a very expensive part and the amp on the woofer adds cost as well. The cost buys greater sensitivity and more projection of the sound into a larger room, neither of which I needed. The M3 and X3 are complementary speakers to fit different needs.
I have not listened to the X3 in person, although the binaural recording on the New Record Day Youtube channel gives a useful comparison.
so I spoke with Clayton at length about which speaker to get.  I ended up with the X3.  I am not 10 feet from them and my room is not large.  But I have to say these things are incredible.  I never demoed the saphires but I have had MG in the past (3.7is)  no comparison when you add the bass to the mix.
