How to know/calculate the current output of your amp?
joffieb
Hi
I have a Rotel RB981 (130W) Power Amp. How do I tell if it is high current? Thanks
Re: How to know/calculate the current output of your amp?
« Reply #1 on: 12 Aug 2021, 03:34 pm »
The term "high current" is arbitrary.  Does it have a relatively massive (big/heavy) power supply?  Is it rated down to 4 ohms or better yet 2 ohms?  A "high current" amp should double the wattage as the impedance of the loudspeaker load is cut in half.  "High current" amps are of particular importance for flat panel loudspeakers.
richidoo
« Reply #2 on: 12 Aug 2021, 04:13 pm »
My guess is it's sourcing about 3A at full power for single channel. That's typical for an amp that size with single pair output transistors per channel on ~40V PS rails.
