0 Members and 1 Guest are viewing this topic. Read 4201 times.
How can I implement this EQ into my system..?Tidal / subscription>InnuOS /streaming server > Holo/ dac > Decware / tube amp > Tekton / speakers
Interesting thread. I currently use RPi players with HiFiBerry Hats (2 using HFB OS and one with PCP OS) and then use a RPI running Raspbian with LMS installed as the source for my local collection along with my Qobuz subscription. Would your system integrate with that?
Tyler here, guys.Oliver (omasciarotte), meet Larry (I.Greyhound Fan). Larry, meet Oliver. You are both in Minnesota
Oliver, where in MN do you live? I live in Woodbury, just 12 minutes east of St. Paul.
Hey Larry,I’m in East Saint Paul off of White Bear Ave, so very close to you! Your setup, using Audirvana as your player, would work. i assume you’re running Audirvana Plus v3, rather than Audirvana Studio. Either will work.Tell me about the analog gear that is downstream of your DAC…
Oliver, I am using the non subscription Audirvana.My gear is a Pass Labs X250 amp, BAT VK51se preamp, Magnepan 1.6 speakers with dual subs. I also have…
https://www.maat.digital/support/#installers
I'm trying to understand what you're selling.I use Foobar.... It has an equalizer that comes with it and volume control. I've also added room correction using a mic. Functionally I have:1 - Player of music from the PC2 - Preamp (a volume control)3 - EQ4 - Room corrected EQDoes your software replace 2 and 3 above or more/less?
