Help with NX Otica crossover mods
0 Members and 1 Guest are viewing this topic. Read 3591 times.
mkrawcz
Re: Help with NX Otica crossover mods
« Reply #20 on: 30 Jul 2021, 01:26 pm »
What to do if VCAP ODAM uF value is not the same as a uF value on a Sonicap? I would order VCAP, but I want a replacement with the same value as my GR provided Sonicap.  Presently, I want to improve my NX Studio crossover.
There is a VCAP ODAM value for the NX Studio tweeter. That is most important. The other cap is in shunt on the midrange circuit. I have not upgraded that one but I do have a Miflex bypass cap on it. If you want to upgrade that one with vcaps, they have a value that is half of what is needed, so you would just get 2 of those per speaker and connected them in parallel. It's more expensive, but it will work.
