0 Members and 1 Guest are viewing this topic. Read 3833 times.
The output level on the RME is switchable from 19db to 1db on the XLR outputs and from 13db to -5db on the RCA outputs so go in the setup and turn it down before investing in new tubes. All should be in the manual. I suspect that the default setting from the factory is probably full output.
