0 Members and 1 Guest are viewing this topic. Read 6040 times.
You should have a listen to the LP version, as it sounds just like what you are describing coming from your CD version.
It’s entirely possible that an earlier pressing of the LP was mastered in QSound, in which case it would presumably sound the same as the CD. My LP is the 2017 Anniversary Edition, remastered by Vic Anseni.
You’re a font of intriguing information, Phil.
I don't remember the Flame Linear but I had two of the one that came after that, the Carver C-4000. Looks to be the same basic thing.It was a fun piece play around with.The things sports fans say to referees, tsk tsk!I asked over on thecarversite if anyone has done a CD-R with a C9 unit so I'll post if there are any replies.
I'll find out for you, there's quite a Carver gear contingent going.I keep hearing really good things about his tube amps, by the way.Kinda wish I would have grabbed the pair that were on here a few months back.
Oh yes, it was discussed back in the day about making holographic cassette tapes.
