rooExtend (External Roon Remote)
0 Members and 1 Guest are viewing this topic. Read 1183 times.
jtwrace
    • TIPP YouTube Channel
« on: 14 Jul 2021, 01:11 pm »
This is pretty slick!  No longer have to have a computer, Android or iOS device open to change tracks or adjust volume.  A device that is always "on" and ready.
https://sellcodes.com/7oWuMUUF
https://rooextend.com/
poseidonsvoice
    • 2 channel/7 channel setup
Re: rooExtend (External Roon Remote)
« Reply #1 on: 15 Jul 2021, 11:55 am »
Sure is! Especially for those of us who are dac direct and don’t want to use the slider VC on Roon while surfing, etc…
Is it Linux compatible or does that not matter as long as you add a Raspberry pi to your listening room/wifi?
Thanks for the info!
Anand.
jtwrace
« Reply #2 on: 15 Jul 2021, 02:31 pm »
Doesn't matter as the RPi Zero is the interface.
