0 Members and 1 Guest are viewing this topic. Read 6782 times.
Hello guys!I know that this may seem repetative, but I'm on the lookout for speakers.My budget is maximum 1000 dollars, but prefer to have it in the 600-800 dollar range.I don't mind used, but it just has to be in good condition.As far as sound characteristics go, I need the following:Lows: Bass extension is somewhat important, bass impact not as much - I want it musical and fitting to the sound, not overly-doneMids: I like it to be natural and musical. The mids are the most important for me, and mid impact is a nice feature tooHighs: I don't mind if they're rolled off as much, just don't make them shrill or grainySoundstage: I just don't want Grado soundstage. I want to be like fifth row center, if possible - not next to the instruments, not in the balconyDetail/Resolution: Not a top priority, but always niceCharacteristic: Warmth is more important than forwardnessI don't mind if they are monitors or floorstanding, but if they are floorstanding I'll need to incorporate stands into the price. If they are large speakers but not quite large enough to call them floorstanders, I have small stands that can get them off the ground, but not as high as required for a monitor.They also must not be REALLY power consuming. For now, I am using a 15watt (8 Ohm) Pioneer SX-450 receiver. It's a great receiver but it also has a bit of a power restraint -- at least I plan on upgrading it some time. My Ohm (Model B) speakers run fine out of it, as a guide. I am satisfied at it turned about 1/10 of the way up!If anybody has a good recommendation, I'd be very appreciative! Thank you in advance!
I don't think a 25 watt integrated from some company nobody's ever heard of is worth 550 bucks. For that kind of money you can get either more power from Rotel among many others or the true toob sound from ASL or Jolida.
Okay, my musical tastes:I really LOVE progressive rock. This means bands like Yes, Jethro Tull, Pink Floyd, and Emerson Lake and Palmer. My top three:1. Progressive Rock2. Chamber Classical3. Jazz Fusion/Acid Jazz
I haven't demoed any speakers yet. Been too busy
When I listen to some Omega's with my receiver, I will go and check out a Vandersteen and probably a Monitor Audio -- if I like one sound better than the other and it requires a new amp, a new amp I'll get!
The reason I keep on considering tube amps is because I generally like the sound better. I mean, if some solid states are more warm, (and I hear the Bluenote is) than some I have heard, then I'll definitely go for it -- I'd love to not have to deal with the hastle of tubes.
The thing I am affraid of with the Vandersteens is that they'll be too laid-back and I won't be able to enjoy the speedy and powerful sections of my Prog music like I should.
