Dumb Question #27
0 Members and 1 Guest are viewing this topic. Read 1172 times.
Julien43
Dumb Question #27
« on: 18 Mar 2005, 12:18 am »
Looking at the trace layout in the Cornet manual, it appears that the outside holes for R18 are for mounting the heatsink/shield for the CCS transistor. Is this correct? Thanks for you paitaince!!
hagtech
Dumb Question #27
« Reply #1 on: 18 Mar 2005, 07:36 am »
Yes, the holes underneath R18 are for the CCS transistor and heat sink.  I put them there to make sure you didn't use both the CCS and the resistor.
jh :)
