New AMBER and JRiver
0 Members and 1 Guest are viewing this topic. Read 9354 times.
jakez
« on: 29 Jun 2021, 01:46 pm »
I just received a new AMBER DAC/AMP from Lampizator - traded in a GA TRP. It's all hooked up, plugged in and turned on. I'm using a Windows 8 machine with JRiver to send music to the Amber. Previously this worked fine with the GA TRP and before that a Big 7. But now I get errors from JRiver - I've updated the Amanero drives as well.
The error is:
Playback could not be started on the output 'ASIO' using the format ''44.1 KHZ 2ch'. The output format is not supported by your hardware.
Any suggestions/advice here? What should the settings in JRiver be?
Or is there a different/better software I should use?
jakez
Re: New AMBER and JRiver
« Reply #1 on: 29 Jun 2021, 02:35 pm »
Needed new drivers from JLSound - up and running now!
wolp
« Reply #2 on: 1 Jul 2021, 05:49 am »
Can you please comment on what you think of the AMBER/DAC AMP? What speakers are you running. Sounds interesting! John
zenwangfr8train
« Reply #3 on: 4 Dec 2021, 06:37 pm »
very interest in  Lampizator AMBER DAC/AMP, Can you tell us more? Thanks!
