X-Statik Build
0 Members and 1 Guest are viewing this topic. Read 8949 times.
cementhead
Re: X-Statik Build
« Reply #40 on: 29 Jul 2021, 09:40 pm »
Does any body have the weight on these completed? I am in the construction phase and am looking into the Gaia footers. Thank you.
subsonic1050
Re: X-Statik Build
« Reply #41 on: 29 Jul 2021, 10:44 pm »
I don't have a measured weight, but I can tell you that just from moving them around I'd guess they are around 50 pounds apiece.
Hobbsmeerkat
Re: X-Statik Build
« Reply #42 on: 29 Jul 2021, 11:29 pm »
That sounds about right for my towers as well.
corndog71
  • Some people call me Rob.
Re: X-Statik Build
« Reply #43 on: 30 Jul 2021, 12:43 am »
Mine are 56 pounds each.
cementhead
Re: X-Statik Build
« Reply #44 on: 30 Jul 2021, 05:50 pm »
Thank you, all. Looks like the Gaia III.
Hollis Prince
Re: X-Statik Build
« Reply #45 on: 1 Aug 2021, 02:09 am »
Does yours have the double baffle all the way down?
I haven't weighed mine. I will when I get home if I can remember. I know they are heavy af
Hobbsmeerkat
Re: X-Statik Build
« Reply #46 on: 1 Aug 2021, 03:14 am »
Ill have to weigh mine once i have them back in hand. Cuz i do have the double thick baffle versions.
Ron is currently out of town tho, and I still need to attach the bases to them but roughly 60lbs sounds about right with drivers, a custom crossover plus 2 sheets of No Rez.
They're not crazy heavy, but they definitely have some heft to them.
