linear power supply for router
0 Members and 1 Guest are viewing this topic. Read 6370 times.
Nick B
Re: linear power supply for router
« Reply #20 on: 10 Jun 2021, 12:36 am »
I recently replaced the cheapo power supply on my Asus mesh router node with a 19v medical grade brick. You'll need an adapter as well, both links below. I was getting a pulsating noise when streaming music, and found that the Asus was the source of it. FWIW, changing the power supply did absolutely nothing, I ended up moving the router out of the room and I use wifi now instead of having my streamer hardwired.
https://www.amazon.com/dp/B07RXHF246/ref=cm_sw_r_cp_api_glt_fabc_5616JKWJER3RS8KR3YKC?_encoding=UTF8&psc=1
https://www.amazon.com/dp/B07JMX76MD/ref=cm_sw_r_sms_api_glt_fabc_3EJMPQ0AG94AQZPN9RKE?_encoding=UTF8&psc=1
Had to look up what mesh router node is. I appreciate the fwiw… that’s why I’m here soliciting opinions. My place is small…. 1,600 sq ft… so one asus handles everything just fine.
Forgot to say thanks, will study in a bit. You found this to be a quiet enough ps?
hifix
« Reply #21 on: 15 Jul 2021, 10:22 pm »
That is very helpful to hear! So in your opinion, it would be worthwhile increasing my budget of $100?
Nick
Hi Nick,
I am sorry that your reply escaped me.  My sincere apologies.
I'm running a 12v power supply (from ebay - with a talema core).  In my room and to my ears it is well worth the $100 or so.
Nick B
« Reply #22 on: 16 Jul 2021, 06:13 am »
Hi Nick,
Thanks for the reply. I ended up buying an adjustable 19-20v unit here on AC. The only problem is the adapter I bought doesn’t fit the ASUS router.
