You didn't mention how many amps the router needs, I would guess not many. My go-to linear regulated power supplies are made by Acopian. The power supplies are industrial quality, built like tanks and last forever so I get mine on eBay.Acopian doesn't make a 19v ps, you would need one of their adjustable models such as the .5 amp Acopian A030MX50 ($260 list) $45 on eBay.https://www.acopian.com/store/wide-l-goldbox-fixedcurt.aspxhttps://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=acopian+A030MX50&_sacat=0&LH_TitleDesc=0&_odkw=acopian+A030MX100&_osacat=0Acopian has Gold Box 18v and 20v ps, pick one that matches the amps you need and plug the model number into eBay. Keep looking until you find a great price. If you only need 1 amp or less but find a cheap 2 amp or 5 amp power supply, that will work too.https://www.acopian.com/store/9-(7).aspx?min=18&max=25If you have kids running around with forks then you will need to make it kid safe because the 120v connections are exposed. This is not a problem in my house.
I have heard of people using the Farad Super3 to power their routers, I use the Farad to power the motor on my turntable. It may be worth a try for you.https://the-ear.net/review-hardware/farad-super3-linear-power-supply
Forgot about the amp listing. Without crawling around on the floor, I’m quite certain it’s 2.7 A
You can get it in the US. Okay best to give it a miss, as it will cost you more than $100.
The amps is probably something you shouldn't guess at, you may be able to find the spec online. Every time I crawl behind my stereo I accidentally unplug something or a wire moves and a hum appears.
Going with a linear supply (or a cleaner power supply) for the router has been a step up for me. Highly recommended upgrade.
As suggested to you before but does not suit your needs the iFi wall wart is a killer for routers. Improved my sound.charles
In case I find something else, is an 18 or 20 v ok or does it need to be exactly 19 v?
Charles,I’m looking at it again right now and the price is quite nice at $100. The ASUS likely uses a 2.5 mm barrel connector…which I presume is standard…. but I’m going to verify thatNick
Which wall wart is it? The iPower?https://ifi-audio.com/products/ipower/At only 15V/1.2A when his router needs 19V/2.37A it just might be a router killer.
If I do get the Acopian, is the voltage measurement as simple as putting one probe on the barrel and the other one inside?
That's it. Watch the meter and turn the screw.Where did you get the idea to put a different ps on the router?
