B&K Sonata M200
damianb
B&K Sonata M200
« on: 8 Jun 2021, 06:17 pm »
Hello audio experts!  I have a very obscure question for you.  Does anyone know what the rocker switch on the back panel on the B&K M200 monoblock is for? Each Monoblock has a balanced and RCA input.  i don't know if the rocker switch should be in the up or down position.  Thank you for your help.
Re: B&K Sonata M200
« Reply #1 on: 9 Jun 2021, 03:48 am »
Gogle for the pdf user manual or test this switch in both positions, you will hear a sound. This is the BK R200 manual at page 4 there is a similar switch that you can verify for free.
https://www.manualslib.com/manual/14238/BAndk-Reference-200-1-S2.html?page=6#manual
« Last Edit: 9 Jun 2021, 08:50 am by FullRangeMan »
