0 Members and 1 Guest are viewing this topic. Read 3264 times.
I had a high quality Marchand active xover. I realized that it was doing more harm than good. After getting used to it, taking it out was like lifting the proverbial "veil". I now run my SAMHOs full range and add powered woofers with signal level input direct from preamp.FMODs are an inexpensive way to play with the active xover concept though.Browsed through those links you posted. Interesting to read some of my past posts and see how things have changed over the years!
In a traditional 2 channel music system that does not output a single LFE channel (like a HT receiver does), you need two: one for L preamp output, one for R. If using one sub, you run both signals into sub, and the sub's internal circuitry combines the signal.If using two subs, run L into one, R into the other.
This thread is interesting to me as the new owner of a pair of Outlaw Super 3XRS speakers with Louis' built-in 8" front-facing hemp cone subwoofers.First, these things are amazing with my Line Magnetic SET amp. However, I don't know where to set the crossover on the sub for optimal blending of the two drivers. I have it around 80hz now but I have the sub's level at just above zero. I am amazed at the bass with these settings but was going to email Louis for his recommendations and to get a better understanding of where I should set the phase pots on each speaker.Thanks,-Chris
