Gustard U12 Digital output re-clocker (converts USB to i2s / AES / EBU output )
0 Members and 1 Guest are viewing this topic. Read 546 times.
dhart86
Gustard U12 re-clocks usb signals and can output via I2s, AES / EBU, Coaxial, or optical fiber. It uses the latest chip U8, inside there are eight cores, with powerful multi-core multi-thread processing capability
Features:
- Screen display shows the sampling rate
- Use XMOS programs to support 32B 384khz asynchronous 2.0 (USB recommended ASIO output)
- Built in power supply
- 44.1 / 88.2 / 176.4 / 352.8Khz and 48/96/192/384
- 4 outputs: Coaxial (RCA), optical fiber, AES / EBU, IIS (HDMI port)
- Coaxial fiber AES / EBU output formats IEC60958 and AES3-r2009 standard limits the maximum support 24Bit / 192kHz; IIS can transmit 32B 384K
- Built-in smart switch, plug in USB automatically
- Two 0.1PPM precision crystal 45.1584M 49.1520M
- International voltage AC115V/230V, the need to manually adjust
- DSD support 128, PCM supports 384K
- Aluminum chassis
- Size: 6.3" × 2" × 4.7"
Asking $100
Buyer pays Shipping and PayPal
