looking to purchase tonearm cable - where should I start
0 Members and 1 Guest are viewing this topic. Read 1598 times.
Danberg
Purchased a used Clear Audio Turntable and messed up (ruined) the turntable arm cable (very thin wires INSIDE the arm).  Want to attempt to rewire myself.  Want a decent to very good cable.  What do you suggest? Are you the source?  Audio circle member said I should look into cardas or discovery cables, can't find a source on the internet.
Kevin P
    • http://www.diycable.com
« Reply #1 on: 16 Mar 2005, 04:25 pm »
Working with 33AWG wires is a real chore.   I sell a lot of the Cardas 4x33AWG which has two pair of twisted 33AWG wires inside of the shielded & jacketed cable.   It was designed specifically for TA use and it is much easier than trying to twist & route your own.
Having said that it is still a challange to terminate the little guys.   It takes good tools, patience and experience.
I sell the 4x33AWG by the foot at the following link.
http://www.diycable.com/main/product_info.php?cPath=89_119_131&products_id=442
If you need cartridge clips Cardas sells them in sets of four.
http://www.diycable.com/main/product_info.php?cPath=26_44_50&products_id=239
I sell both the gold plated ones and the Rhoudium ones at an upcharge.
All in stock.
