0 Members and 1 Guest are viewing this topic. Read 9559 times.
I like Firefox because it has the broadest range of well-made security and privacy extensions like u-Block Origin and NoScript.
"Background Update is now available on Windows. This feature will allow Firefox to update, even if it is not running. It will be slowly rolled out to all Windows users over the next few months."
I never had a problem with Firefox (90.0b1 64 bit) although the next update will be a big consternation to some in this thread:"Background Update is now available on Windows. This feature will allow Firefox to update, even if it is not running. It will be slowly rolled out to all Windows users over the next few months."I have run the Adblock ad-on forever and my reaction to targeted ads is "Facebook has ads? I didn't know that"The Facebook Container extension puts a fence around Facebook so they can no longer track your movements after you leave their site (bet you didn't know they did that).Malwarebytes Premium + Browser Guard stops any malicious downloads or trojans. Malwarebytes Premium has realtime protection plus it stops all ransomware attacks. I would never ever consider having a computer without it, the software catches stuff missed by an antivirus program so running both is absolutely necessary.Along with Eset NOD32 antivirus I fearlessly go anywhere and everywhere on the internet.I tried the Tor Browser but it broke too many websites.https://www.torproject.org/download/
Probably I am misunderstanding. The choice to disable automatic updates remains in the General Options settings where it has been for years. I just double checked this on Firefox 89 on a Windows 10 machine and a Mac.Perhaps you aren't scrolling down when you go to Options-->General? It is down the screen a ways.
The option that was deleted by Mozila was Never Update FF.
The developers figured out Never Update was probably a bad idea. All those companies that have been hacked recently never updated.Under the General setting
With Norton Security, MalwareBytes-Browser Guard (at your advice) Eset is not redundant? If it isn't, what does it provide the others don't?
I'm sure you found it already, but this worked for me:about:configsearch for "browser.proton.enabled" and set to falsesearch for "browser.proton.contextmenus.enabled" and set to falseThere are still a few minor changes I'm not happy with (super light tab colors), but the big issue of double-spaced bookmarks is fixed.
Norton products used to be a system hog and noticeably slowed a computer down, I stopped using their products for that reason. I hear they have improved.
I must still be misunderstanding. The second option means Firefox will never update unless you manually initiate the update. It is identical to "Never Update FF"Not only can you stop Firefox from updating itself (as a built-in setting), you can install any previous version of Firefox that you would prefer:https://ftp.mozilla.org/pub/firefox/releases/
This helps A LOT. The other thing I found that helps is "clean brushed steel" theme, although I'd like to remove the texture... I just wanted to find one that didn't feel like it was... I dunno... BURNING MY FUCKING RETINAS. Who decided this was an upgrade? DAmn... so bad. Ok I found win 95/98 gray and it's probably the best so far for themes.
They're still a memory hog, computers have gotten fast enough with enough memory that with a few improvements to their platform you don't notice it as much. It still slows my old Win 10 laptop down if it decides to run a scan while I'm doing something.
The option I was referring was this> Never Check for Updates
If security and privacy are a concern, a secure and private browser complements a VPN but can never be a substitute for a good VPN. ...
I have been avoiding VPN because of the large speed hit.
Got it. You can disable checking for updates using a policies.json file. On a Windows system you make a folder wherever the firefox .exe file is located. This folder is named "distribution" without the quotation marks and with a lowercase d. This, and all of the settings available, is documented by Mozilla: https://github.com/mozilla/policy-templates/blob/master/READ6ME.mdTo create the policies.json file you would open a basic text editor (I guess Notepad on a Windows machine?) and just paste in the settings desired. Save the file with the name policies.json (and make sure the text editor does not tack a .txt file extention on the end. The file extension is .json) Below is a set of useful ones: I have installed these and they are working on Firefox v89. Changing the text from true to false allows control of the setting. If you want an older style separate seach bar to the left of the address bar, the last setting can be changed from unified to separate.{ "policies": { "DisableAppUpdate": true, "DisableFirefoxAccounts": true, "DisableFirefoxStudies": true, "DisablePocket": true, "DisableTelemetry": true, "DontCheckDefaultBrowser": true, "SearchBar": "unified" }}I found the list of settings above on the forum linked below, but the placement of the policies.json file given in the posting is out of date. The Mozilla documentation linked above specifies the correct placement of policies.json file for v.89.https://linuxreviews.org/HOWTO_Make_Mozilla_Firefox_Stop_Nagging_You_About_Updates_And_Other_Annoying_Idiocy
