Klipsch RP 600 Upgrade Kit
0 Members and 1 Guest are viewing this topic. Read 1015 times.
Spazmodee
« on: 20 May 2021, 05:42 pm »
Hi Group,
This is my first post. Just received the Klipsch RP 600 upgrade kit. Im a total newb, but watching the videos made it look fun and doable. would appreciate any more detailed direction on the crossover assembly.
Thanks in advance!
Mark
Tubefly
  • Motorcycles, Music, and Trout
Re: Klipsch RP 600 Upgrade Kit
« Reply #1 on: 20 May 2021, 07:05 pm »
Have you watched this from Youtube
https://www.youtube.com/watch?v=rIxig_9i-Iw
Hobbsmeerkat
« Reply #2 on: 20 May 2021, 07:11 pm »
Just lay them out according to the diagram, and connect them as shown. All caps and resistors should be oriented so that text reads left to right, inductors are less important with which side is in or out.
However inductors need to be mounted perpendicular to one another, with the large one laying down, and smaller one standing up like this chart here.
Be sure your crossover layout/board can easily fit inside, (be sure to account for the volume of the Norez as well) and that all your connections are securely twisted before soldering them together.
Feel free to message anyone or give Danny a call if you get stuck.
If you post pictures, just be sure to cover up the values of the caps
Shives
  • I like French fries
« Reply #3 on: 20 May 2021, 07:56 pm »
https://www.audiocircle.com/index.php?topic=166535.0
Official thread is in the link above for the RP-600m GR build. Good luck!! Should be fun!! Welcome
Spazmodee
« Reply #4 on: 20 May 2021, 09:51 pm »
Awesome, thanks so much for the guidance!
