Anyone know the SWL Linestage remote codes?
0 Members and 1 Guest are viewing this topic. Read 2126 times.
Chris_B
« on: 15 Mar 2005, 03:01 am »
Does anyone know the 4 digit code that Dan uses for the All4one remote?
Chris
ted_b
« Reply #1 on: 16 Mar 2005, 01:47 pm »
No.  I could create and send you a Pronto ccf (vol +, vol-, mute), but that's it.  Within ProntoEdit you can see the ir codes.
Does anyone know where the ir receptor is?  I was originally gonna have Dan put a mono mini-plug ir port on the back, cuz the angle I use from my sweetspot is problematic.  It ended up delaying the build and shipment too much so I opted out, but now wish I had.  I will just put an ir transmitter (sticky) on it but can't figure out where the receiver is.  Maybe it's the small plastic dot above the tape monitor loop.  I was gonna email Dan but since he is on vacation I thought I'd ask the "first 49 gang".  :)
Ted
modwright
    • ModWright Instruments
Remote Code
« Reply #2 on: 28 Mar 2005, 07:37 pm »
The Remote Code for the ModWright remote is: 1242.
Dan
Chris_B
« Reply #3 on: 29 Mar 2005, 02:00 am »
Dan - I had to send my Oneforall remote back to have 1242 added.  After it came back, it accepts the code now but vol+/-/mute don't work.  The good news is that the remote has 4 learning buttons which I have trained.
