Cheep and cheerful tube/valve amps
0 Members and 1 Guest are viewing this topic. Read 2343 times.
Shives
  • I like French fries
« on: 14 May 2021, 02:17 pm »
Hello!! Looking to get into the tube area of life.
So, I was going to jump in and build a Tu-8600s, then I thought about a few different builds.
So, I’m looking for suggestions for tube amps that are inexpensive, and have decent sound. Something I can tube roll, and if I get board or it warrants it, I would have no problem upgrading the caps, resistors, transformers, really anything.
Id like a little project basically. But again, something that’s not starting at 1800 for the parts with no tubes. I would be into someone’s project they did not finish of anyone has one..
Was looking on EBay and Amazon for inexpensive units, and they are filled. I bow down to all of you, or any of you whom have more knowledge and can point to some directions.
I don’t have a Pre-amp other then my Denon AVR which had a pre amp mode. I would be looking to purchase a Dac/preamp combo as well (maybe gustard x16 if it has pre amp ability have to look) again very open to suggestions to get me a cheep and cheerful tube amp!!
Must be cheerful!
sarora9
Re: Cheep and cheerful tube/valve amps
« Reply #1 on: 14 May 2021, 02:22 pm »
I have my eyes on this one: https://www.audiocircle.com/index.php?topic=167568.0
Basic kit is around $600-650
Poultrygeist
« Reply #2 on: 21 May 2021, 10:33 am »
I.Greyhound Fan
« Reply #3 on: 21 May 2021, 05:07 pm »
https://spudkit.com
I find it odd that they do not publish the wpc and parts used.
Poultrygeist
« Reply #4 on: 21 May 2021, 07:57 pm »
 In the description it states the power is 2 to 3 watts which is about what you would expect from a single ended tube amp of this type.
leica m3
« Reply #5 on: 21 May 2021, 09:39 pm »
Take a look at the kits from Bottlehead. They are fun to build with almost moron proof assembly instructions.
brl0301
« Reply #6 on: 2 Jun 2021, 01:09 am »
https://spudkit.com
+1 on this!! I built one a few months ago and it sounds as good as amps 3x the cost!
