0 Members and 1 Guest are viewing this topic. Read 4327 times.
So I recently picked up a new turntable (Schiit Sol) and want to upgrade its cartridge. I put my Ortofon 2M Blue on there from my old Thorens and it sounds really lively and punchy, but I want to upgrade to a LOMC and see how that sounds. My phono pre is a Project Tube Box S2 so it has the gain and loading options to be able to try one. My question is how far down the rabbit hole do I go on the upgrade? I was looking at the Hana ML as a suitable big upgrade, but I can't help wondering "what if" on something even higher grade like a Micro Benz Zebra or Soundsmith Zephyr Star ES. I know the rest of my setup doesn't warrant such distinguished quality, but if it's a forever upgrade (especially with the re-tip program of Soundsmith) then it could be enjoyable. Am I barking up the wrong tree wasting money or would it be a noticeable improvement to go all in on the upgrade? Any advise is welcomed. Thanks!
Hearing all the positive reviews on how smooth the Soundsmith is, definitely has me leaning that direction. Also the rebuild program is a HUGE plus for long term enjoyment. As for the phono pre, it does support lomc, just uses dip switches on the bottom. It doesn't have the huge adjustability to really fine tune impedence, but it can go in the ballpark ranges of both sides of their recommendation just not the 7-800 medium range.I guess that really was the real point of my question though. Given the rest of my setup is more entry level,, would it make more sense to make incremental upgrades to more components or go all in on cartridge and wait longer to upgrade the next piece?
In discussing options, I've decided on the Soundsmith Aida is the ticket. The real clincher is it will be a better match compliance with the lower mass arm on the Schiit. It still uses a lot of the same stylus and cantilever features of the Zephyr Star, rebuildable for cheap, and most importantly will be one hell of a big upgrade in sound. I feel this will be an excellent happy medium between all the options. Thank you for all the help! Now time to go be broke and completely happy.
