SVS 3000 Micro anyone?
0 Members and 1 Guest are viewing this topic. Read 2492 times.
artur9
« on: 8 May 2021, 03:06 pm »
Anyone out there experienced the SVS 3000 Micro dual opposed 8 inch subwoofers?
Always looking for musical small subwoofers to use as a stereo pair.
https://www.svsound.com/products/3000-micro-subwoofer
trianglezerius
Re: SVS 3000 Micro anyone?
« Reply #1 on: 19 May 2021, 11:15 am »
I bought one and it will be here today.
« Reply #2 on: 19 May 2021, 12:11 pm »
Like the idea of opposing woofers but not much smaller than the cheaper SVS SB-1000 that specs out slightly better.
trianglezerius
« Reply #3 on: 19 May 2021, 12:18 pm »
I have to consider size.
Craig B
« Reply #4 on: 19 May 2021, 12:34 pm »
Didn't KEF just come out with a small sub, too? Don't recall the model number, but you can't miss it if you see it - all rounded corners, and said to be the size of a soccer ball (or football, as they say :wink:).
trianglezerius
« Reply #5 on: 19 May 2021, 12:47 pm »
The KEF uses 6.5 inch drivers and that's to small for me.
artur9
« Reply #6 on: 20 May 2021, 03:06 am »
I think the KEF is also twice the price or some such.
I have an SB1000 and I think it's huge.  I also have some Velodyne SC8 that are a good size.  I was thinking SC10s would be better but couldn't find any.
Freo-1
« Reply #7 on: 21 May 2021, 12:30 am »
I talked to the SVS folks about this.  Its a great choice in smaller rooms.    My room is 24 x17 x 10, so they said even a pair of them would not suffice.
trianglezerius
« Reply #8 on: 31 May 2021, 12:27 pm »
The sub out of the box was awful but dialing it in and some time on it it's a keeper.
I.Greyhound Fan
« Reply #9 on: 31 May 2021, 04:44 pm »
You should also consider a Martin Logan Dynamo 800x which has a small footprint.  I use  2 very old original Dynamo's in my 17'x17' room with 9' ceilings. One sounded very good in the room. The 800x is non ported and uses a 10" driver.  It is rated at 24-200 Hz +/- 3db.
https://www.martinlogan.com/en/product/dynamo-800x
You can find used Dynamo 700's for a good price.  It is the older version but it does not have an app I think.
artur9
« Reply #10 on: 1 Jun 2021, 03:42 am »
Looks like those ML 800's are significantly bigger: 14.6" x 12.4" x 12.7"
trianglezerius
« Reply #11 on: 1 Jun 2021, 12:32 pm »
Thx for the suggestions but I won't buy a sub without adjustable phase by 1 degree.
