I recently simulated the circuitry for a new spin on our amp technology....With very realistic component values and some clever tweaks, I was able to get THD at rated lower down to 0.00002%. Yes, that’s FOUR zeros.Interestingly, the original purpose of the changes was to increase damping factor at high frequencies, which these new circuits also do quite well. The simulations take a long time, some more than an hour for a very particular scenario, so I run them in the background when there’s time.What amount of THD (or lower) do you believe is “essentially distortion free”?
Wanted to re-visit my May 8th post. I hope it did not come across as sounding or appearing as being unhappy! Nothing of the sort here as its just simply the finest amplifier I have ever owned. We all have our own biases whether it be room size or acoustic damping / defusing panels etc. For instance I have always had a problem with the power band of music around the 1Khz range, before and after. When I mention midrange warmth its in this area I like more recessed and laid back. Different speakers can change this as we know. Will be rolling my Acoustat 1100s back in soon for hopefully a short listen. Will be bi-wired like my Electron SE are now, same cables etc. Lets see how the precieved difference in DB plays out. Thanks Tommy for your stellar products!!
The DAC amps are extremely clean and less distortion can be a really good thing. It's already amazing sounding amp line. If its now a better sounding amp, it is a good thing for the audio world. Tommy- Specs aside, can you share if the amp sounds better with this change? Cheers.
the output impedance is close enough to zero that damping factor over 1000 is easily exceeded. That's where trace, wire, and connector resistance actually make a difference.
There's no such thing as a "perfect amplifier", but we're getting closer!
And by the time you put a voice coil in series (not to mention that oft seen first inductor), the real damping factor is somehwere 20-40ish. Why not just specify Rout. Damping is a marketing dept creation to make a small number look big. A step closer would be variable out so you could dial in the amount of electrical damping applied to the loudspeaker. Too low is only an asset if you have a speaker with an ugly/significantly non-flat speaker impedance. It is possible to overdamp the loudspeaker.dave
I will beg to differ.dave
+1
I am all for people having a difference of opinion. I am even more in favor of people having strong convictions. That’s what makes this forum what it is.Curious to what you “differ”?
