Industry Circles
GR Research
Danny Richie
Greetings and X-SLS build!
0 Members and 1 Guest are viewing this topic. Read 3301 times.
coopman
Re: Greetings and X-SLS build!
Reply #20 on:
16 May 2021, 02:25 am »
The big box that the cabinets came in contained a lot of sheets of foam padding. I am wondering if I could use this foam padding as internal lining for the cabinets?
Ethan Macfarlane
Reply #21 on:
16 May 2021, 09:38 pm »
Any reason not to have the crossover on the top like pictured? Then I can get the brace behind the woofer properly.
Ethan Macfarlane
Reply #22 on:
16 May 2021, 09:39 pm »
Or on the side wall then I could get all th braces in.
Ethan Macfarlane
Reply #23 on:
16 May 2021, 10:18 pm »
For the internal filling is there any difference between using wool insulation (i have a load around) vs polly fill which i would have to buy?
Thanks again everyone!
Hobbsmeerkat
Industry Participant
Reply #24 on:
16 May 2021, 10:36 pm »
Either placement will work just fine, so long as the crossover is properly secured to the cabinet walls.
As for infill, its all a matter of taste, some are fine with polyfill, others prefer fiberglass and some prefer natural wool or cotton options.
Industry Circles
GR Research
Danny Richie
