SVS Ultra Bookshelf’s! Install and upgrades!
0 Members and 1 Guest are viewing this topic. Read 4460 times.
Shives
  • I like French fries
« on: 29 Apr 2021, 09:25 pm »
Hello!!
Just starting a new upgrade! I’ll share a bit quickly and then come back to add some more later on, cause it’s time for food and fuel!
So, funny... local guy to me called GR when I was visiting.. the guy asked if anyone could assemble them before shipment.... NO! Lol this is something that the crew don’t have time for, that’s why we are here to help! But, Danny right away stated.. “I got someone I think can help”
So, here we are!! They are in the works, and the center is next!! After which he wants to also do the towers, so this should be a fun, and nice build! Lucky he’s close to avoid shipping, more so the towers. Easy meet up!
The drivers actually look nice, much better then what I’ve seen in some I’ve taken apart.. not a stamped basket.
The factory crossover is a joke! But very dainty and cute! Bite size! It’s easy to see what this line up of upgrades are going to do!
Mounting parts network parts on 3/8ths cherry! These will be painted with a liquid acoustic treatment, in black. No staining.
I’ve gotten the parts all figured out for the order I want to put them. I got one board soldered up, and both cut!
Binding cup is all taken apart, and ready for drilling. The wire used at factory is again, a joke.. So the upgraded wire will be heaven sent.
Stay tuned.. I need to eat.
Shives
Re: SVS Ultra Bookshelf’s! Install and upgrades!
« Reply #1 on: 2 May 2021, 03:14 pm »
Ahh some quick updates to the SVS build.
Had a big weekend of Jack and Jill’s and more. So, trying to fit these in. We have a bike blessing going on today as well.
Bare with me.
My helper.
Ok, so one speaker is done, the other started. I have more photos to upload but need some editing.
This is going forward smoothly. I actually like these speakers quiet a bit. The mid driver seems to be of decent construction. It’s not a stamped steel basket, and a fiber construction cone. The tweeters look decent as well construction of both of the drivers seem a bit better then the average unit. Nicer then Klipsch.
The stock network is of the worst I’ve seen. Has a nice coil, but it’s so small. Removing the binding post were a bit of a pain, they are covered in that sticky blue locking material. Box has a great brace right in the middle! Rear ported, so keep them away from the walls.
Network boards are covered in the black spray matting I’ve used for years. I’ve also went back and glued them down for extra security. Board is wired up, again 4 post on this network to hit. Negative is shared, with input and both speakers. Positive as well is shared for both input to circuit. Then just pick the correct output for your tweet and mid! Simple wire up. I can say in this kit, the wire length is plenty enough! You should not need anymore! How ever, I think it might be best to grab extra heat shrink.
I’ve noticed over the last couple packages sent the heat shrink varies quiet a bit in length. I feel that you should get a full 12 in of red and 12 inch of white. I’m once again ran out. The point of the heat shrink is to cover your soldered connections on the network, the speakers and the tube connectors. That alone, and connections normally about 1 inch in length. Do the math.. we have 4 connections on the board itself.. then 4 for the speakers. Then 2-4 for the input area. So, getting 6 inches of red and 6 of white.. I’m sorry it’s not enough.
Folks, I strongly urge you to use a two part epoxy for the tube connections. Takes an extra 15-20 minutes and it’s a great piece of mind knowing they are solid in place. I use hot glue as a backup to what ever first method I use. Tie down, then glue. This was actually using the spay as a hold down, then zip tied as well some hot glue to make sure they hold.
I see everyone is twisting there wire! Good! Don’t go over board! You don’t need to twist it so tight you loose 4 inches. A nice wrap around each other is plenty fine! As well you will notice due to the solid conductor it does not want to “go in the box” as easy when installing drivers. Help the wire go back, don’t force it. Looser wraps will help it tuck a little more easy.
So, the only connections I did not heat shrink are the extra 5-way binding posts I also wired for side by side. Also, I use this line for my customers in helping them think of the best ways. I tell them leave the posts! At least one set! This way if you ever want to move the speakers for say a party or what not.. you can then just use the binding posts. You may notice the difference when doing so.. BUT, your friend won’t, and they will think they sound amazing!!! Then bring them back into your room, hook up those tube connectors and watch as they experience sound in a whole new level.
Since these are ported.. I did not opt to use any fiberglass. Yes, fiber glass is a bit better then Pollyfill. Yet, with ported designs I have seen fibers shoot out of the port. Not knowing if kids are at play.. Polly I feel is safe. The difference won’t be huge! Better then glass particles shooting into the air. Keep that in mind folks.
I’m excited to hear these next to my Klipsch. Actually second thought.. maybe I don’t want to a-b these... I have enough projects going and don’t want to build anything but the XLs at this point. Lol.
Don’t cover the port when pushing Polly back in. Keep that clear. Oh, and take it easy with this wood finish! It can mark very easy, and I feel the cabinets on the outside are a bit soft. So driver slides into the hole I don’t suggest. Take ease installing and removing. The drivers do provide a cool gap on each side to grab and move. It does help a little. As well, the holes for the drivers are a bit tight! Not a bad thing! Just take ease when removing.
That’s all for now!
My Klipsch are almost done being broken in. At that point will do a better write up of my thoughts. I do have to REW my 504C today for another member that’s getting some strange results after his install of parts. This leads me to a whole different topic.
This is a no gripe, not being mean, just being honest mention.
To those who’ve purchased kits for installing! Please make sure the first thing you do is take all your parts out, count them, and check them with the schematic that’s in the box. If you don’t have that, contact Danny right away. We are all human and things can happen! So, if you get a schematic that states you need two .35 coils.. and you get a .37 there is a difference! Make sure before you solder and install all your parts match the sheet given! Sometimes mistakes can happen! They are not done on purpose! It’s a mistake! The part numbers can be very close and they are small to read! (Trust me, I’ve done some measuring for him and putting them away, even I got confused at one point!) (Tho it’s awesome to see parts come in with your hand writing on them. I feel, it just makes me smile a little.) Listen, I get-off on helping people. It’s my happy place! Don’t judge.
Look at all your parts! Count them up, and check them off the list given. If anything is wrong, please contact Danny right away! He will go the lengths to make it right! To my guys in the shop... J and K... your doing great! We thank you! But, double check everything.
 Listen, these guys got orders! 200 orders and 3 guys! Give them a brake!
Ok, today ill be finishing the ultraBooks and on to the center.
So, I know some are reading this. I’m going to maybe start another post to ask this.
I hope some are reading this.
Those whom are building these DIY kits for others! As mentioned, it’s not the hardest, but tedious it very much is, and time consuming. You can’t just snap these out in 1 hour.
 For people you do not know, what are you charging folks to build these? Thanks. You can PM me if you prefer! Just trying to gauge what to charge. I could have sworn I was told 250-300 for the books and half that for the center. Again I’ll make an official post asking this. I want to keep in-line with the rest of you! As well, I feel it’s only fair, and justified to Danny that we keep all of our prices very close! I’m sure I don’t have to explain why! But for those who wonder, we are assembling someone else’s hard work! (Danny’s) We are helping those whom have not purchased all the tools to do this, as well may not have the abilities.
Tools don’t come cheep, nor does your knowledge! Being fair is what’s needed. I feel if we can all play together, it may help those around them do more! Again, this helps your pocket, as well GR selling more products.  More fair, and perfect our installs the more the work comes about, more we are trusted. I’m here to help all aspects! So to those only!!! What have you charged? Again, we are not talking for your dad you may have done them free for. We are talking for those people who just call you out of the blue.
Thanks all. Few of you have my phone number for those late night, what the hell did I do questions. I don’t mind, just remember I’m east coast time! So 12am to you, might be 1-3 for me. Lolol.
More to come
Shives
« Reply #2 on: 2 May 2021, 03:39 pm »
Missed these photos.
Shives
« Reply #3 on: 5 May 2021, 08:07 pm »
Over-all I think these came out great! The guy who owns them will be happy. There is a brace In the speaker. I would buy a sheet of no res and get rid of the stuff that’s in there. I did not listen to these long, just wanted to add some photos to help anyone who’s looking to build.
I’ll come back and add some more, need to get cracking on the SVS ultra center. This one will be challenging! It’s actually built well, decent braces. Mid area is sealed. Crossovers are split. To which not much room to make one unit, so I’m going to make two. One for the tweeter and combine the mid and outer woofers, or combine the woofer and tweeter.. seeing that will split up the induction better.
I’ll start a post on this. Anyone who does the center, pay attention to the schematic. This will be different then normal bookshelves. Space! Not much!
Stay tuned. Keep building.
« Last Edit: 6 May 2021, 12:45 pm by Shives »
Hobbsmeerkat
« Reply #4 on: 6 May 2021, 12:00 am »
Thats a really clean upgrade! Even without the norez, I'm sure it sounds great! :thumb:
RonP
« Reply #5 on: 6 May 2021, 12:46 am »
It must be embarrassing for them to take a speaker labelled "ultra" and upgrade the sound performance.  :icon_twisted:
just saying
daltonlanny
« Reply #6 on: 21 Jan 2023, 12:05 am »
Hello,
Just curious if there is anyone out there who could assemble the crossover and wires if I send the parts for a fee?
I wouldn't need to send the speakers, just would like someone with experience to build the crossovers and attach the wires for me.
If there is someone who can please PM me and give me the details.
Hobbsmeerkat
« Reply #7 on: 21 Jan 2023, 02:40 am »
daltonlanny
« Reply #8 on: 21 Jan 2023, 05:46 am »
Thanks for the information!
daltonlanny
« Reply #9 on: 23 Jan 2023, 07:32 pm »
Hey Shives,
you do some great looking work on those crossover boards.
daltonlanny
« Reply #10 on: 2 Jul 2023, 10:23 pm »
If anyone happens to have a pair of stock SVS Ultra bookshelf crossovers laying around, I would be interested in purchasing them for experimentation.
Let me know.
jerzyboy1210
« Reply #11 on: 8 Dec 2024, 04:10 pm »
Thank you so much for sharing this and the Ultra Center upgrade post. I'm new to this corssover world and have completed upgrades for these and the Center thanks to you!
One question: the diagram for the Ultra Center that came with the upgrade kit shows the woofers being wired with opposite polarity. Is that still correct for how you did it? I ask because, while running room correction, I received an error message about polarity for the Center speaker only and it gave me the option to ignore the error.
I appreciate any input :)
Danny Richie
« Reply #12 on: 24 Dec 2024, 07:19 pm »
Yes, the woofers have polarity flip. That is common.
