Well Tempered Classic Bearing Cup
Dave2010
« on: 28 Apr 2021, 12:06 pm »
Hi all, I'm trying to extract the baering cup from the external tank. I try to put a finger into it and try to extract but without success.
Any suggestions?
Thank you
familytree2000
Re: Well Tempered Classic Bearing Cup
« Reply #1 on: 3 May 2021, 04:05 pm »
HI.  Your talking about the cup in the center right?   you should be able to push it up from the bottom of the table?  Be aware it might pull up some of the paint/plastic cause its glued.  Just some steady pressure and wiggling.  Good luck.
NZmember
« Reply #2 on: 16 Aug 2021, 08:20 am »
Snug fit but should pop out by hand - unless someone glued it in...
