0 Members and 1 Guest are viewing this topic. Read 6446 times.
Well, years ago the APPJ/Miniwatt 2.5 watt tube amp was a real giant killer and had a lot of commercial success. Then they offered a few more versions. Not sure if those are still around, but they were under $500 and 2.5 watts would be plenty with the La Scalas. I have owned one since around 2009-10, and used in primarily in my TV system, though for the first couple years it was in my main rig. Worked great with Hornshoppe Horns and also Tekton Lores. After about 7 years of nearly daily use, it started periodically randomly powering down for 10-15 seconds at a time while in use. So, not designed to last forever. But at your price point, nothing will be. Still a solid recommendation, especially with some upgraded tubes.I also owned a pair of 1978 La Scalas from 2000-2006, so I know what that's all about. Bob, are your La Scala crossovers all-originals? Or have they had any upgrades?
If you post your question in the Talkin’ Tubes section of the Klipsch forum you will get excellent advice from guys, including amp designers and builders, with extensive experience in this area. There are also thousands of posts you can review for recommendations.
Could you point me to that forum? Sorry, I searched and can't find it?thxbob
OP is shopping for <$500 amps, so I assume is not interested in high cost crossover updates.
I don’t disagree that there are much better out there than the Tube Cube. But am glad you have a Tube Cube on the way for instantaneous satisfaction and to have a decent back up while you explore other options. But I would recommend you also place some Crites crossover upgrades high on your priority list. Those ancient oil caps are not doing you any favors, and the La Scalas are so dynamic that crossover hash will hold back performance of any amp you use to power them.
i see im a little late to the party but if you are interested/capable of doing the soldering yourself, the spudkit amp sounds way better than it should for the price it sells. for. I built one a few months ago and have been running it on my cornscalas and it sounds great. I think the kit is around 400 bux with tubes.
