0 Members and 1 Guest are viewing this topic. Read 10705 times.
Also there is the Wright Audio Royale full integrated with balance control and hard wiring at $1555 mad in usa, transformers are bigger than Decware.http://www.wrightaudio.us/royale_SE6.htm
I was just using the Decware (familiar to me since I live 81 miles/130km away) as an example of EL34 set rated power.Since you mention Wright (which curiously I can fine no/zero reviews on), it is rated for 7 watts single ended triode.Are the transformers really larger or do they just look that way?
We are way off topic, but enclosed vs open frame opts can be deceiving in size and performance.You do you, making absolute judgements on things from miles away and no experience.
Here's the link to the triode (and other) mods.https://filedn.com/l7UsPK07cbB4Azv0FsTo1rH/A10%20modifications.pdfChina Hi Fi shows the power as 6W*2 (as does Amazon) and that is what's stated in the info included w/ the amp.https://www.china-hifi-audio.com/en/reisong-tube-amplifier-boyuurange-audio-c-48/reisong-a10-el34-tube-amp-single-end-class-a-amplifier-boyuurange-p-1300?zenid=52f25156eda72ee21d07965cb8008660Cheers
Would converting to Triode mode lower the power output? What in layman terms is the difference (in this amp) between UL and Triode mode?thxbob
Triode use elements Cathode, grid, Anode.Pentode use Cathode, grid, screen, anode.UL use cathode, grid, anode, being the grid connected to the anode(output), hence the bigger power.
Thanks, Can this amp run in Pentode mode since EL 34 is a Pentode?bob
The A10 ? No.I read carefuly the China Hifi page and the spec say its only UL, some amps do Triode and UL, in this case there is a switch on the board.This video on PCBs may help you on amp choice:https://www.youtube.com/watch?v=tsL-i8nFvdA
Thanks, Check this thread out for extensive modding on the A10. WAY above my pay grade, tho!https://www.diyaudio.com/forums/tubes-valves/266925-boyuu-hifi-equis-a10-el34b-6n2-se-tube-amplifier-5z4p-rectifier-review-mod.html?fbclid=IwAR0ZQVYiXuTUWviUIOeDsKm1KaOgBma8Y6VoojI7jRfSReZ88nxyFmN9oR0
No thanks, I already run this road, modify a cheap amp may become a expensive project.
Hey! Wow! I looked at the upgrade list. That's like building a new amp and still get stuck with stock output transformers! Yeah, I agreed on that. With this amp it will be like trying to make the least expensive Hyundai sport car into BMW M sport cars. With this amp, I think the only logical upgrade is changing those Orange drop coupling caps to something else to fine tune the sound a bit. Buddy
