NAD Masters M22 V2 wattage output
Falcon
« on: 13 Apr 2021, 11:31 pm »
I don't attach a lot of emphasis on having an amp that can double wattage output from 8 ohm to 4 ohms, but I do respect companies that accomplish that. I was looking at the rated output for the M22 and it claims the same output, 300 watts from 8 to 4 ohms. I'm wondering what kind of output circuits don't up the output at all when halving impedance? Could this be a negative attribute for this amplifier?
They rate the "Dynamic" output wattage as almost doubling when impedance is halved. I've read somewhere that the dynamic wattage ratings can be ignored, more a selling point than anything else. What are your thoughts on that?
RDavidson
Re: NAD Masters M22 V2 wattage output
« Reply #1 on: 14 Apr 2021, 01:44 am »
This is NAD's way of saying the amp is load agnostic.
Letitroll98
  • Too loud is just right
« Reply #2 on: 14 Apr 2021, 09:27 am »
It's a class D amp, they output the same regardless of load.  The IHF dynamic load is measured at 1kHz with 1% distortion.  Hope that helps.
opnly bafld
« Reply #3 on: 14 Apr 2021, 02:09 pm »
 :scratch:
I see other class D amplifiers that increase with lower impedance.
NAD has rated power into 8 and 4 ohms the same for a long time, even with their class A/B amplifiers.
C272 from 2003-07
https://nadelectronics.com/wp-content/uploads/2017/03/Data-Sheet-C-272-Stereo-Power-Amplifier.pdf
 :dunno:
opnly bafld
« Reply #4 on: 14 Apr 2021, 02:23 pm »
From Stereophile measurements of the amplifier (V1) that I assume you are asking about:
Fig.4 indicates that the THD+N reaches 1% (our usual definition of clipping) at 340Wpc into 8 ohms (25.3dBW). Fig.5 shows that the M22 clips at 400Wpc into 4 ohms with both channels continuously driven (23dBW), while with just one channel driven (fig.6), the amplifier clips at 570W (24.55dBW). Even into 2 ohms, the NAD M22 managed to output 700W (22.4dBW) with just one channel driven.
NAD's Masters Series M22 amplifier measures extraordinarily well. It is the very model of a modern class-D amplifier!—John Atkinson
https://www.stereophile.com/content/nad-masters-series-m22-power-amplifier-measurements
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #5 on: 14 Apr 2021, 03:34 pm »
From those last quoted numbers it would appear that the amplifier is power supply current) limited such that it starts to “sag” into lower impedances.
dave
