Amp, pre-amp and DAC for your 1801s
0 Members and 2 Guests are viewing this topic. Read 2661 times.
Al Garay
« on: 13 Mar 2005, 07:44 am »
If you are searching for electronics to run your 1801s, these work extremely well:
* AKSA 55 watt with Nirvana upgrade
* BentAudio preamp like NOH or TX102
* ART DI/O Mensa modified DAC (I tried the AcK Dack! and it's not as good a match with the Bent and replacing the battery will get expensive in a hurry).
Add a DVD player and/or Slimdevices Squeezebox (music server) and you have a true high-end system for music and 2 channel HT.
I'm selling this package
http://www.audiocircle.com/index.php?topic=17532
thanks,
Al
Foxyb
And here's another one that works
« Reply #1 on: 24 Mar 2005, 02:21 pm »
I run my 1801f's with:
Roksan rok-dp1 CD Transport
Audio Synthesis Dax DAC
John Linsley Hood 80W mosfet amp modified to use better psu and feedback caps
Rega planar 3 turntable with john linsley hood phono amp
u-byte 2 speaker cable (2 cross-connected CT125) cables
Silver signal tape interconnect.
I am very happy with the setup, until I decide I must change the amp!
rmihai0
« Reply #2 on: 24 Mar 2005, 02:26 pm »
Linsey Hood - wow - finally I meet someone who is using this famous amplifier. I never listen to it. Can you help me with some details about it? Tell world about this amplifier - is not known here in North America.
Foxyb
Linsey hood 80W mosfet (not the class A one), and the DAC
« Reply #3 on: 31 Mar 2005, 07:45 am »
Hi,
The amp comes from a kit from HART electronics here in the UK. Mine has great component quality on the AMP boards, sounds sweet and truthful, but does not have a dual mono power supply which would definately improve it, but at a cost!
I like the sound, fast, smooth and detailed. I imagine an AKSA is better though. I cannot easily compare these two.
I was told that the 80W linsey hood compares to amps costing £1000 in the UK. I think that it is better than that.
John
