Outside hose reel?
0 Members and 1 Guest are viewing this topic. Read 2919 times.
jtwrace
    • TIPP YouTube Channel
Outside hose reel?
« on: 11 Apr 2021, 11:15 pm »
Does anyone have an automatic retract hose reel (outside rated) they like so much you recommend it?  Can it hold a 5/8" hose?  If so, please share!  < $400 preferred.
twitch54
Re: Outside hose reel?
« Reply #1 on: 11 Apr 2021, 11:54 pm »
JT, just get a good Suncast and crank it !
jtwrace
« Reply #2 on: 12 Apr 2021, 02:22 am »
If I'm cranking, I'm getting an Eley.   ;)
twitch54
« Reply #3 on: 12 Apr 2021, 03:04 pm »
I like my hoses out of sight when not used. I've been using this one for years now and couldn't be happier
https://www.suncast.com/smt200wdj.html
mcgsxr
« Reply #4 on: 12 Apr 2021, 06:52 pm »
I had a Suncast auto reel for around 8 years.  It worked well for about 5 (I always bring them into the garage for winter) but then it would "slip" and I would end up having to "feed" the hose into it while it ran.  I did like that it watered my trees near the hose reel when autoreeling.
Once it died, I bought a boring old manual reel cart.  8 years running perfectly so far.  I don't mind the look, and it's great to not have to play around with it.  The manual reeling works well for the 125ft of hose I have.
