Scatter plate for 244 availability
veloceleste
« on: 7 Apr 2021, 06:23 pm »
Hi, Are the scatter plates available for full range, full size 24”x48”  244 panels? The option is not showing in the cart. Also is it possible to order just one 244? Thanks.
JWL.GIK
    • GIK Acoustics
Re: Scatter plate for 244 availability
« Reply #1 on: 7 Apr 2021, 06:25 pm »
Hi veloceleste,
You can only order full boxes online, if you want partial boxes email details and I can write up a manual invoice.
Scatter Plates are available as an option when you put the 244 in the cart. If they are already in the cart without plates, click to edit that item. When you are back on teh 244 option page, add the Scatter Plate in the options, then add it back to the cart. You can add a Scatter Plate on one or both 244s in n the box.
