0 Members and 1 Guest are viewing this topic. Read 8811 times.
I would be worried about the following with the LFT-8b:"The speakers are not beamy horizontally as far as individual driver responses are concerned, but there is “lobing” between the midrange and tweeter on account of the broad overlap in frequency range from the shallow-slope crossovers and the side-by-side placement. (It would be preferable in principle to have two midrange panels on either side of the tweeter, it seems to me, to get a sort of horizontal MTM effect. This would stabilize the imaging.) In any case, the particular configuration here creates some imaging effects that are both not quite correct and also unstable with respect to head movements. You have to be really careful about where you sit and how you angle the speakers to avoid hearing the drivers as separate sources. Beware of careless audition: Exact set-up and exact listener position are crucial here. But if one sets up the speakers ideally—and doesn’t move!—this becomes much less of a problem."https://www.theabsolutesound.com/articles/eminent-technology-lft-8b-loudspeakerSounds like a complete headache to me, and recipe for never being fully satisfied with the sound. You're not going to have the above problem with the Spatial speakers.
I have owned the LFT-8bs and I think they are a great bargain at their price. Yes, they should have a good 100watt amp and in larger rooms depending on your music tastes for bass, you will need a subwoofer or two. I would also recommend bi-wiring if looking to get the last ounce of goodness from them. There are very few speakers in their price range that can match them in from 200-20,000hz. Vocals, particularly female voices sound incredible. They can play loud enough if the room is not to large. Bass response is better when bi-wired. Replace them with speakers over four time more expensive and honestly they are not four times better!
There have been some mixed reviews on them, are they still very fussy with placement and do they suffer from a small sweet spot?
I didn't find them any more fussy than any other planar speaker to place when I had them, and for what it is worth, I had the best success slightly angling the speaker back by raising/spiking up the front of the speaker to open up the sound/add some more spaciousness I didn't get when they were level front to back.In my instance, they did have a pretty small sweet spot (and even more so vertically; you really need to be seated in the middle vertically of the tweeters; they dropped off like a rock when listened too at all off axis) but what you got in that sweet spot for the frequency range of the midrange and tweeter was really, really good.Also, the power specs from the manual were pretty spot on in my experience in terms of maximizing performance. 200wpc solid state with a lot of current drive had them playing nicely.
That's a pretty big room.What is your price range?
