New midwoofer mod for RM-40s
audiochef
went for 40s huh?
« Reply #20 on: 17 Mar 2005, 02:37 pm »
Warnerwh,
  So you couln'nt resist one of the besyt buys in the audio world . Copycat. Whats  your initial impression?
THough 40s  are more state of the art,I,d bet the Rs will always retain something special. Deservedly.
Cogrdulations, Stan
warnerwh
« Reply #21 on: 17 Mar 2005, 11:32 pm »
Thanks Stan, you're right the R's are an excellent speaker and used prices are a super bargain along with the FF3 and FF1's.  Fortunately a very close friend will be using them so they're still in the family.
The RM 40's are amazing I think and you're right they have to be one of the best buys in audio. Bass is excellent  and the midrange and treble are certainly outstanding.  I'd heard a pair of RM 40's over at Soundguy3's house a couple of times and was one of the people who felt the upper bass lower midrange was a little thin.  At the same time I knew I had to have that midrange and treble.  Inner detail is amazing. The new midwoofer totally ameliorated the upper bass thinness problem.  These things also throw a soundstage that the R's can't match and the bass is pounding all over the place.  The potency of the low bass for ten inch woofers is impressive and at the same time being more accurate I feel than the 15's, at least to the low end of the music spectrum, but it's close.
Joshk: I ordered my speakers about 3 weeks ago.  I ordered complete speakers systems, not just the upgrade.
audiochef
new woofers
« Reply #22 on: 18 Mar 2005, 12:35 am »
Warnerwh ,Just picked up the new midbasses. I'm surprised their so heafty. looks exactly like megawoofer.
Installing now. report soon
Stan
BY the way , was checking out the planers on the  Rs . I'll probably get them.
koteng
Re: new woofers
« Reply #23 on: 18 Mar 2005, 09:46 am »
Quote from: audiochef
Stan
Hi Stan,
Could you tell me the impedance of the new woofer?
And what is the value of the extra capasitor shipped with it?
I just don't understand how a bigger capasitor can make the crossover freqency higher?  :?:
Roger
audiochef
woofer specs
« Reply #24 on: 18 Mar 2005, 03:28 pm »
Woofer is 8 ohms. I don,t know the value of caps AURIES though.
Too much in a hurry to install.
Email  Brian for this  info.
Second impressions ,Bass is very fast and tight.
Brian Cheney
    • http://www.vmpsaudio.com
upgrade
« Reply #25 on: 18 Mar 2005, 05:32 pm »
The new midwoofer makes for an impedance change, the cap compensates for it.
doug s.
  • makin' music
Re: upgrade
« Reply #26 on: 18 Mar 2005, 08:32 pm »
Quote from: Brian Cheney
brian, does this mean retrofitting the midwoofer to older models does not change the x-over point?  what add'l stuff is needed to raise the low/mid x-over point to 280hz?
thanks,
doug s.
Brian Cheney
change
« Reply #27 on: 18 Mar 2005, 09:32 pm »
Xover point after mod is 280Hz, all accomplished with impedance change.
doug s.
  • makin' music
Re: change
« Reply #28 on: 18 Mar 2005, 09:33 pm »
thanks brian...
koteng
Re: woofer specs
« Reply #29 on: 19 Mar 2005, 09:14 am »
Isn't the impedance of the old midwoofer also 8 ohms?
Roger
