I just returned from Tyson's where I changed out his midwoofers and changed the midrange crossover.He did take a photo of the old and new drivers. Hopefully he will post it later.The installation of the crossover caps is VERY easy, as Marbles has written elsewhere.You just have to pull the base and the passive radiator off. The crossover is right there. You will add the new caps to the midrange stack o'caps.There was an immediate change for the better. There is now an impact to the bass that was not there before.The changes also improved imaging.There is now a cohesiveness to the sound that I was not aware was missing.The integration of the planar drivers and the cones are much improved. ...
Tyson forgot to pick up the dowels There was no bloat or looseness, as you described. If anything the bass was too tight. A small amount of putty removal helped with that.
I haven't braced my cabinets yet, and I'm not sure why my results are different than Marble's results, ..
Now, for the sound, I'll say that it didn't meet my expectations. I expected the mid and upper bass to get stronger (which it did), and I expected the bass to overpower the mids and require major re-tuning to get the mids and highs sounding good again (it did not).Bass is definitely much stronger, the upper bass finally matches the quantity of low bass I've been getting since the beginning. In fact bass impact is outstanding. But the thing that suprised me was that the midrange became even more pure ...
Would you mind comparing the RM30's to the RM40's in a seperate thread?
