Today's Smile
I.Greyhound Fan
Re: Today's Smile
« Reply #5360 on: 31 Mar 2026, 03:54 pm »
(Bolt)
My GUESS is that the head of the screw can be removed from the shaft???
That's what I was thinking as well, but how do you remove the screw then because the top may unscrew first and then you are stuck cutting the bolt out but maybe that's the plan by design?
brooklyn
Re: Today's Smile
« Reply #5361 on: 31 Mar 2026, 08:19 pm »
I know, AI.. just kidding. who's to say that bolt isn't in two pieces.. A larger portion screwed in from the
top and a small portion screwed in from the bottom.. Thats my idea and I'm sticking with it..  :)
brooklyn
Re: Today's Smile
« Reply #5362 on: 1 Apr 2026, 01:56 am »
jschwenker
Re: Today's Smile
« Reply #5363 on: 1 Apr 2026, 02:28 am »
The Bolt:
As a former McComical Engineer (among other specialties):
My guess is that the hole in the casting is slotted a little in the left-right direction to allow tilting in of the bolt.
Not shown in the photo but that would also then be advisedly a good place to use a washer under the bolt head.
Alain Arseneault
  • Double A
Re: Today's Smile
« Reply #5364 on: 1 Apr 2026, 09:50 am »
Laundrew
Re: Today's Smile
« Reply #5365 on: 1 Apr 2026, 12:01 pm »
AllanS
Re: Today's Smile
« Reply #5366 on: 1 Apr 2026, 01:00 pm »
The Bolt:
And then a mfg engr nightmare because you can’t get a torque wrench on it.  I’m going with AI.
jschwenker
Re: Today's Smile
« Reply #5367 on: 1 Apr 2026, 02:13 pm »
Agreed. Does complicate matters. Would need a torque wrench accessory, additional procedures and up-trained workers.
nlitworld
Re: Today's Smile
« Reply #5368 on: 1 Apr 2026, 02:26 pm »
I always use the gauge of tighten it just past where my wife would complain that I tighten things too much. Won't come loose, and I get to mess with her a bit.
*also works on Mason jars, lightbulbs, toothpaste caps, and all your favorite water bottle lids.  :lol:
Zuman
Re: Today's Smile
« Reply #5369 on: 1 Apr 2026, 02:42 pm »
My nephew is a mechanical engineer with MIT's Lincoln Laboratory. He says that it's either a photoshopped image or that the casting has a slot or notch that is being obscured in the photo.
Alain Arseneault
  • Double A
Re: Today's Smile
« Reply #5370 on: 2 Apr 2026, 10:35 am »
Laundrew
Re: Today's Smile
« Reply #5371 on: 2 Apr 2026, 12:13 pm »
Alain Arseneault
  • Double A
Re: Today's Smile
« Reply #5372 on: 3 Apr 2026, 08:42 am »
Laundrew
Re: Today's Smile
« Reply #5373 on: 3 Apr 2026, 11:32 am »
Alain Arseneault
  • Double A
Re: Today's Smile
« Reply #5374 on: 4 Apr 2026, 10:04 am »
Laundrew
Re: Today's Smile
« Reply #5375 on: 4 Apr 2026, 11:34 am »
AllanS
Re: Today's Smile
« Reply #5376 on: 4 Apr 2026, 01:34 pm »
This reminded me of the mall heat transfer t shirt shops.  Maybe gen Z will bring them back along with the mall.
https://www.usatoday.com/story/money/2026/03/26/gen-z-retail-shopping-malls-resurgence/89233505007/
Alain Arseneault
  • Double A
Re: Today's Smile
« Reply #5377 on: 5 Apr 2026, 10:01 am »
Laundrew
Re: Today's Smile
« Reply #5378 on: 5 Apr 2026, 11:58 am »
Alain Arseneault
  • Double A
Re: Today's Smile
« Reply #5379 on: 6 Apr 2026, 09:03 am »
