Audio/Video Gear and Systems
Owner's Circles
Omega Speaker Owners
New here. ? About Audio Note IZero with Omegas
0 Members and 1 Guest are viewing this topic. Read 1781 times.
brojr
15 Mar 2021, 02:37 pm »
I am thinking of a purchase of a Audio Note IZero integrated @ 8 watts a channel. Also looking at the Omega 7 mkii. Any thoughts on this combo? I listen to Mainly Classical & Jazz. 15 x 15 room. Moving from higher wattage tubes. Thanks.
dolsey01
Re: New here. ? About Audio Note IZero with Omegas
17 Mar 2021, 02:06 pm »
The iZero had no problem driving my Ryan R630s (4Ohm 88db) so it should easily drive the much more efficient Omegas.
I was really surprised how well it did and how good it sounds.
NoDisco
Reply #2 on:
17 Mar 2021, 06:55 pm »
If you’re set on audionote...you’re set on audionote. Lots of great amps out there in this price range or less that do omegas justice. Are you predisposed to tubes?
brojr
Reply #3 on:
19 Mar 2021, 12:58 pm »
I'm just looking at integrated amps that will work well with the Omegas. Budget is around $2k. I really like the sound of tubes. If there is a SS that will come close I'm in.
Owner's Circles
