60V Power Supply To DAC 2 Connection
LarryD56
« on: 28 Feb 2021, 04:57 pm »
 What connector is used between the 60V power supply and the DAC? There are so many different types of those small connectors that I want to make sure I buy the correct one.
   Larry D.
DRHamp
Re: 60V Power Supply To DAC 2 Connection
« Reply #1 on: 28 Feb 2021, 05:08 pm »
Get one from Tommy and it will be the right one:
LarryD56
« Reply #2 on: 1 Mar 2021, 05:31 am »
It's either a 5.5 x 2.1mm or a 5.5 x2.5mm. I'm not sure which one or I'd just go and buy one today. Need a 2 foot long cord.
L.D.
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
« Reply #3 on: 2 Mar 2021, 05:19 pm »
First, does your power supply have a 12VDC jack?  If so, it should have come with the power supply.
AmpDesigner333
« Reply #4 on: 2 Mar 2021, 05:22 pm »
L.D.
It's a 2.1mm connector, standard type.  This should work:
https://www.amazon.com/dp/B00GPVWRRC
