Designing a Sealed enclosure using a M130 driver(*)
0 Members and 1 Guest are viewing this topic. Read 1701 times.
ttan98
« on: 23 Feb 2021, 03:33 am »
Danny,
A fairly easy question you can answer on top of your head. I still own 2 units(New) of your M130, 5" drivers(in fact I own 4units so far used 2 units).
I found the midrange performance to be very good. I want to design a sealed enclosure for this unit. So can you advise me:
1. Optimum size of the enclosure, for the maximal flat roll-off at the bottom end?
2. What is the -3dB freq. at the bottom end?
BTW enjoy your Youtube channel. Thanks.
* I want use them as Omnidirectional driver, so no baffle step is required.
Danny Richie
Re: Designing a Sealed enclosure using a M130 driver(*)
« Reply #1 on: 28 Feb 2021, 01:56 am »
You'll need .26 to .28 cubic feet of air space.
The -3db down will be low 70's but with a gradual roll off.
ttan98
« Reply #2 on: 28 Feb 2021, 03:23 am »
Do appreciate your assistance many thanks.
