Do you leave your Cherry amp powered up all the time?
0 Members and 1 Guest are viewing this topic. Read 2389 times.
Francis_Mcg
Just curious, I do, but should I?
DRHamp
Re: Do you leave your Cherry amp powered up all the time?
« Reply #1 on: 20 Feb 2021, 02:47 am »
Yes
LarryD56
« Reply #2 on: 20 Feb 2021, 05:28 am »
I'm frugal, so no I don't.
L.D.
rodge827
« Reply #3 on: 20 Feb 2021, 10:10 am »
As long as your well protected it shouldn't be a problem. Tommy says that his gear doesn't need a long warm up time 20 mins or so and your good. When I had my DAC gear I left it on all the time. Years ago I was told to leave my dac on all the time to keep the chips warm. Since then all my digital gear is left on.
Chris
MttBsh
« Reply #4 on: 20 Feb 2021, 04:47 pm »
Just to distinguish between "on" and "off" the STM - as well as many other DAC products - has a separate power supply. I leave the power supply switched on but turn the amp on and off (to stand by). I've learned that the power supply switch can wear out over time and thus it's best not to continue turning it on and off, just leave it on.
Francis_Mcg
« Reply #5 on: 20 Feb 2021, 05:23 pm »
FWIW, I own the 'classic' Cherry amp. Just the single power switch on the back.
Related - does anyone know what my amp draws at idle? A lot or a little?
Jack1949D
« Reply #6 on: 20 Feb 2021, 05:26 pm »
My 5-CHerry amp is left on all the time and as you probably know the channels go into sleep mode when not in use.
GregC
« Reply #7 on: 20 Feb 2021, 10:22 pm »
I leave my linear PSUs powered up for my Golden Cherry amps (and the amps do not have the sleep feature).
Nsm1979
« Reply #8 on: 21 Feb 2021, 06:24 am »
I leave the power supply on 24/7.  My Inline King Maraschinos have the sleep feature, but since inserting a Bluesound Node 2i in my system to feed the DAC DAC HS 1, the amps no longer go into sleep mode.  They stay on 24/7 now.
Anyone know how to get the sleep mode to work properly when using a Node 2i?
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
« Reply #9 on: 24 Feb 2021, 04:09 am »
Answers in this thread:
https://www.audiocircle.com/index.php?topic=175052.0
