McIntosh MC1502 with Magnepan MG-0.7
0 Members and 1 Guest are viewing this topic. Read 1532 times.
miatadan
« on: 16 Feb 2021, 10:50 pm »
I know that high power SS are suggested as best match for Magnepan speakers.
Considering that tube power amplifiers continue to improve, would the new MC1502 have issues driving the Magnepan 0.7 speakers?
Also using 2 JL Audio d110 subs in stereo
Right now using the MC312 and rarely using more than 30watts per channel.
This amplifier  ( MC1502 ) is 150 watts per channel
Dan
Craig B
Re: McIntosh MC1502 with Magnepan MG-0.7
« Reply #1 on: 17 Feb 2021, 12:44 pm »
The folks at Magnepan will tell you that high current is more important than high power. They (and others) will also tell you that for the average consumer, the best way to determine if an amp has sufficient current is to check its power output into 8 ohms and into 4. If it doubles its wattage into 4 (or close to it), while all other parameters stay the same (frequency range and distortion figures), then it's a high-current design. I'm not an electrical engineer, nor do I have access to whatever test equipment could actually measure amplifier current, but my last two power amps were better in that 8/4-ohm wattage measurement than my first two, and they sound much better with the Maggies I've owned (right now I'm driving my .7s with a pair of PS Audio M700 monoblocks).
rollo
  • Rollo Audio Consulting -
« Reply #2 on: 17 Feb 2021, 03:32 pm »
  You can certainly use tubed power. Just bring plenty of power.  Carver ??
charles
SteveFord
« Reply #3 on: 17 Feb 2021, 04:40 pm »
That MC1502 will be fine.
