Micro Audio Switching power supplies for audio applications
0 Members and 1 Guest are viewing this topic. Read 4386 times.
microsim
    • Micro Audio
Hello
I would like to introduce myself and my products also.
I am a designer and developer for switching power supplies for audio applications.
I have many products made for audio applications.
Sam
microsim
    • Micro Audio
Re: Micro Audio Switching power supplies for audio applications
« Reply #1 on: 13 Feb 2021, 02:52 pm »
I would like to mention that the new SMPS1K-PFCR2 is the perfect choice for Purifi amplifiers.
Forgot to add the website
www.micro-audio.com/store
richidoo
« Reply #2 on: 13 Feb 2021, 06:03 pm »
Welcome to AudioCircle, Sam!
Your products look cool  :thumb:
My class D amp has a built in SMPS and I have been very happy with the sound of it, plus it runs cool and no big tranny. Seems to be the wave of the future.
Is there a +/-15V version for preamp?
microsim
    • Micro Audio
« Reply #3 on: 13 Feb 2021, 06:08 pm »
Hi,
Yes, All SMPS products have a regulated AUX voltage from +-12VDC up to +-24VDC.
In addition to an extra 12V and 3.3V and VDR voltage for the driver stage of class-d amplifiers.
Some models have PFC for superior performance.
jtwrace
    • TIPP YouTube Channel
« Reply #4 on: 13 Feb 2021, 06:08 pm »
What is the advantage to your SMPS over the OEM?  Where are you located?  Do you provide any objective data of the amp output with your SMPS vs the OEM?
microsim
    • Micro Audio
« Reply #5 on: 13 Feb 2021, 06:32 pm »
Advantages are
1- Using highest grade components
2- Excellent technical support
3- These SMPS units proved better sonics than others, with some amplifiers like Purifi for example.
I don't have any data of any amplifier output with my SMPS connected to it.
I am only making excellent SMPS out of passion!
I am located in AMMAN - JORDAN.
Thank you
Phil A
« Reply #6 on: 13 Feb 2021, 07:14 pm »
Welcome!
microsim
    • Micro Audio
microsim
    • Micro Audio
« Reply #8 on: 15 Feb 2021, 11:25 pm »
Got these from a friend, the output of his amplifier in idle connected to the SMPS630-SO, and one while the amplifier is loaded.
Hope that helps!
Focus Fidelity
  • https://www.focusfidelity.com
    • Focus Fidelity - Digital Room Correction
« Reply #9 on: 10 Jul 2021, 08:54 pm »
Wow, this is impressive work.
Does the SMPS1K-PFCR2 have the same mounting hole pattern as the hypex SMPS1200?
It would be good if the SMPS1K-PFCR2 could bolt straight into one of these https://www.ghentaudio.com/kit/purifi-eval2-mono.html
microsim
    • Micro Audio
« Reply #10 on: 31 Aug 2021, 10:39 pm »
Yes, SMPS1k-PFCR2 has the same pattern of screws underneath the SMPS, but I am afraid that it won't fit when it comes to the size, as this SMPS has way more futures than the HYPEX so the size will increase.
I can provide you with the STEP file if you like.
I am sorry I didn't see your post because I never got any notifications.
Thank you
