0 Members and 1 Guest are viewing this topic. Read 2533 times.
In nearly 50 years at this I've not found a single tweak that is beneficial, including various cable risers.
Cheapest and most likely to cause discussion is to use empty toilet paper tubes as risers. cut them in half and snip a pair of U or V shaped slots place on end slot up, place cable on. Free except for a little time involved.If toilet paper tubes causes distress among those unable to dissociate from the use/origins of the tube... use paper towel roll tubes...If you like them, paint them black.. buying the paint raises the cost from zero to a few bucks..If you are really lazy, just use the tubes as is, (instead of cutting them) laid down and the wires over the roller like tubes.Other folks use shot glasses, bits of wood (I now use exotic wood blocks myself)
I'll bet that really keeps the shit flowing.Don
