Pairing remote with epot3max
glynnw
  • I have tin ears.
« on: 29 Jan 2021, 08:27 pm »
Can you direct me to directions for pairing remote with latest epot3max?  I have looked and tried instructions for V2 but no success.
tortugaranger
    • Tortuga Audio
Re: Pairing remote with epot3max
« Reply #1 on: 29 Jan 2021, 09:03 pm »
The pairing process is essentially the same for all models. It only works with the Silver metallic Apple remote.
1) Turn on the preamp via press/release of the encoder pushbutton
2) Then press/hold in the encoder pushbutton for 20+ seconds at which point the preamp enters pairing mode
3) Then press any button on the remote but recommend you press the center/enter button
That's it. At this point the preamp should respond to the remote.
It's described in our online documentation: https://tortugaaudio.com/docs/apple-remote-pairing/
Let me know if this doesn't work but we use this procedure almost every day so I know it works if the procedure is followed.
glynnw
  • I have tin ears.
« Reply #2 on: 29 Jan 2021, 09:52 pm »
Worked as advertised!  Thanks, as always.  I am convinced that this latest model sounds better than the previous ones.  Anyone else feel this way?
