Opinions sought: Name the one, two or three best midrange drivers.
AJinFLA
  • Soundfield Audio Loudspeakers
    • Soundfield Audio
AJ!!!
Where the heck have you been?
Kill me already.  :lol: Hmm. I'll bet I can learn a thing or two by checking your website, huh?  :wink:
Still here. "Best" is rather subjective. Best for you? I'd think you were eminently more qualified than I, regarding such. :)
Good luck of course, whether that be cones, domes, stats, horns, etc..
cheers,
AJ
LesterSleepsIn
  • Occasionally consternated
The GR Research Studio Monitor kit is one of the best speakers I’ve ever heard and would be a good fit here,  but it needs a sub or 2.
And you’re referring to the NX studio monitor?
https://www.gr-research.com/store/p14/NX-Studio.html
Yep, here's my review of it after I got to spend a couple days at GR Research listening to all their top end models:
https://www.audiocircle.com/index.php?topic=167137.0
DaveC113
  • ZenWaveAudio.com
Best mid is the one that sounds closest in character to the woofer and tweeter you're using.  :wink:
It also depends on goals. If clean symphonic reproduction is the goal you need more ways, hard cones and steep slopes. If simple music and lower cost is the goal, maybe a higher efficiency paper-cone wideband midrange with the woofer and tweeter only augmenting at frequency extremes is best.
