0 Members and 1 Guest are viewing this topic. Read 9813 times.
Some of my favorite speakers are those that capture the entire vocal range with on bass/midrange or midrange driver.Ideally the range of 100hz to 4khz would be covered by the midrange driver. I’ve found the Altec 414A to be difficult to beat in this range.
This range is also covered by a variety of electrostatic panels and ribbons, although the good ones are invariably proprietary
Tyson mentioned the GR monitor with the Neo 10, chosen for its ability to play low enough to hand off to OB subs. But BG Neo 8 is as good (or better?) if you are handing off to a more traditional woofer. And the already mentioned the old Altec drivers are also amazing. I don't understand why, but the Altec 416A can produce great vocals... it makes no sense in a 15" driver.
My 2 cents, which is worth about that much, is that you already have great speakers that fit well into that room and that you're happy with. If bass is the problem, why are we talking mid-range drivers? Build a couple of subwoofers as you mentioned, better and deeper bass than you can get in any three way.
What are these LS 5’s?
