Where do I start?
0 Members and 1 Guest are viewing this topic. Read 1704 times.
dman777
Where do I start?
« on: 9 Mar 2005, 03:40 am »
Ok, I tried a digital receiver and I found I don't like the digital sound. I remember back in the 1990's I had a Technics receiver that had an awsome full sound. I checked on ebay and didn't see the model I used to have and I don't want to keep buying Technics receivers not knowing if I will like how each individual unit will sound. So, what are some good receivers or amps(around 250.00 or less) that have a good full warm sound without that digital harsh, cold, empty sound? Where do I even start since most receivers made today have that digital sound even though they are not even 100% digital?
bubba966
Where do I start?
« Reply #1 on: 9 Mar 2005, 03:53 am »
Start with this one
http://www.costco.com/Browse/Product.aspx?Prodid=11007280&whse=BC&topnav=&cat=3840&hierPath=79*3840*
it fits this descrition rather well
gongos
Where do I start?
« Reply #2 on: 9 Mar 2005, 03:55 am »
What digital receiver did you try? What does your system consist of?
miklorsmith
Don't Trash Digital Sound
« Reply #3 on: 9 Mar 2005, 06:49 pm »
from just one bad experience.  Digital can be done poorly or it can be done well, just like any other strategy.  In fact, if you are looking at quality watts for minimal dollars, digital is probably your best bet.
Tripath-based receivers are known to generally be softer sounding and are widely praised for having a distinctly "un-digital" sound.
dave_c
Where do I start?
« Reply #4 on: 9 Mar 2005, 07:20 pm »
what kind of speakers are you using?
dman777
Where do I start?
« Reply #5 on: 9 Mar 2005, 08:41 pm »
Ok, I figured it out....I want to go with seperates and I want just an amp...one that will lean more to the analog sound. What's out there for around $250.00?
-Dman
StereoMods
    • http://www.stereomods.com
Slim pickings
« Reply #6 on: 10 Mar 2005, 03:44 am »
At that price range I'd shoot for a used B&K. Not too sexy, but about the best you'll find at that price point.
Good luck!
